Activity Forums Apple Final Cut Pro Odd Select Clip Behaviour
  • Odd Select Clip Behaviour
    Posted by Eddie Torre on July 12, 2011 at 12:36 am
    So like many, I use JKL to shuttle through my footage.
    Also, I have the “Select Clip” command mapped to a keystroke (T).
    Normally, what I would do is use JKL to shuttle, then immediately press T to select a clip in the timeline. It should work in theory, but for some reason, it works sporadically.
    It seems like I have to go back and move the playehad in order to regain the ability to use the select clip command.
    So instead of
    JKL and then “Select Clip” (works sometimes)
    I have to use this instead
    JKL, move the playhead, then “Select Clip”
    I was wondering if somebody could confirm this behaviour.
    I guess I’m looking for the equivalent of “Mark Clip” from FCP 7 and it doesn’t seem like “Select Clip” is doing the trick unless I am missing something.
    Eddie Torre replied 15 years, 2 months ago 3 Members · 3 Replies
  • Hector Berrebi
    July 12, 2011 at 10:42 am
    Are you JKLing with skim function turned on?
    This may cause what you describe…
    S turns it on and off
    Hector Berrebi
    prePost Consulting
  • Patrice Freymond
    July 12, 2011 at 12:52 pm
    Not a skimmer issue, at least not here (as we seem to have different bugs sometimes depending on setups)
    In fact hitting C (for select clip) only works when the playhead is moving, through j-k-l or spacebar commands. As soon as you hit k or the space bar you can not select the clip…
    patrice
    Patrice Freymond
    Senior editor
    FCP Certified Trainer
    patrice@monteur.tv
  • Eddie Torre
    July 12, 2011 at 4:54 pm
    Yes that seems to be it.
    It works with J and L, but not K.
    Thanks for your help guys.
