Activity Forums Adobe Premiere Pro Odd render issue
  • Odd render issue
    Posted by John Hutelmyer on January 6, 2014 at 4:33 pm
    I’m having an odd render issue with Premiere CC. I am up to date on updates and am working on a MacBook Pro circa early 2011. 15 inch. 2.3 GHz Intel Core i7 | 16 GB 1333 MHz DDR3 | AMD Radeon HD 6750M 1024 mb | OSX 10.8.4
    I have a timeline that is pretty basic, but the main video (AVCHD) is being keyed out and there is an 8 point garbage matte applied as well as some color correction. Everything looks fine in the viewer.
    When I go to render though, it almost looks like there is another mask being applied to the interviewee, and essentially her head is being cut off.
    In the image below, you can see what everything looks like in the timeline.
    This image shows what the render looks like:
    I’ve tried different render settings and formats, but the main delivery I need is simply an .h264 for YouTube…nothing fancy. I’ve also tried moving the position of the garbage matt effect in the effect viewer but still get the same results.
    Any thoughts?
    Gary Huff replied 12 years, 8 months ago 2 Members · 2 Replies
  • John Hutelmyer
    January 6, 2014 at 4:39 pm
    I may have already solved the issue, I changed the renderer to not include OPEN CL and initial tests seem fine. I wonder if a recent CC update caused it to switch renderers as I did not consciously change it at any point.
    Still, does anyone have thoughts on why this issue may have happened?
  • Gary Huff
    January 6, 2014 at 5:06 pm
    [John Hutelmyer] “I changed the renderer to not include OPEN CL and initial tests seem fine.”
    Let us know if that fixes it. Whenever I have any kind of error like this, that’s the first thing I do. I just assume that the GPU supported rendering is still buggy in spots. If it does fix your issue, it would be best to submit a ticket to Adobe so they can fix this.
