Activity › Forums › VEGAS Pro › Odd overlaps between every file that i drag and drop into Vegas 5.0 *
  • Odd overlaps between every file that i drag and drop into Vegas 5.0 *
    Posted by James on April 11, 2005 at 6:38 pm
    Hello!
    i’m using DVgate to capture minidv video on my Vaio.
    and it splits the video into 2048mb size files. When i drag and drop them into
    Vegas 5.0 … it creates this verrrry small overlap with a
    crossfade between each video clip, therefore creating a
    split second of lost video.
    When i play it back , it makes a quick clicking noise
    when it passes through the small crossfade. AND it makes
    it very hard to sync up the video and audio. (i’m syncing
    4 camera angles together)
    In vegas 4.0, it did not do this.
    In 4.0, when i dragged a clip…it had the full size upside down
    triangle between the 2 clips. (right above the timeline)
    BUT in 5.0, it’s got the half upside
    down triangle – along with the crossfade.
    i don’t know if i accidentally changed a setting somewhere in vegas 4.0 or 5.0
    what can/should i do about this?
    thanks
    Peter Wright replied 21 years, 5 months ago 3 Members · 10 Replies
  • 10 Replies
  • Edward Troxel
    April 11, 2005 at 6:54 pm
    Options – Preferences – Editing tab. Turn OFF “Automatically overlap multiple selected media when added”
    Edward Troxel
    JETDV Scripts
  • James
    April 11, 2005 at 7:27 pm
    THanks for your response, BUT
    when i went to do that…the
    box was already UNchecked.
    doesn’t that mean it was already off?
    i also changed the setting under that one
    from .250 to 0.00
    that didn’t seem to do anything either.
  • Edward Troxel
    April 11, 2005 at 9:26 pm
    Then I’m not sure what’s happening. What if you double-click each one of them? After it’s added to the timeline it should move the cursor to the end automatically. Then just double-click the next one.
    Edward Troxel
    JETDV Scripts
  • James
    April 11, 2005 at 10:13 pm
    thanks jedi…that worked (to an extent)
    NOW, i have a different, yet related problem. 🙁
    now i’m getting the full triangle right over the timeline.
    (showing that the video files are NOT overlapping anymore! 🙂
    However….now the audio part of each file…is a little shorter
    than the video part of the file. what is up with that?
  • Edward Troxel
    April 12, 2005 at 12:12 am
    The audio being shorter is probably why you were getting the overlaps.
    Edward Troxel
    JETDV Scripts
  • Peter Wright
    April 12, 2005 at 12:39 am
    Thinking laterally – it sounds as if the drive you’re capturing to is formatted FAT32 which is causing the files to be split when it hits a max file size limit. Reformatting to NTFS will remove this restriction.
    Also, I don’t know DV Gate, but is there a reason you’re using this rather than Vegas to capture?
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • James
    yeah…you’re right.
    but the funny thing is-
    is that on one clip , the
    video is a hair shorter than
    the audio. weird stuff.
    i think i’m just gonna have to
    re-capture. i guess i’m gonna
    try the vegas capture program.
    can it capture analog as well as dv?
  • Peter Wright
    April 12, 2005 at 12:44 am
    Yes – to capture via a pass through device such as a DV cam or A-V converter, you need to turn Device Control off in Capture prefs, otherwise Vegas will be looking for a DV tape to control.
    Peter Wright
    Perth, Western Oz
  • James
    April 12, 2005 at 12:54 am
    i just went and checked the hard drives-
    they are both ntfs. looks like i’ll have to try vegas capture.
    one more question,
    in vegas capture—does it capture dv as one long
    file?
    thanks
  • Peter Wright
    April 12, 2005 at 1:00 am
    Yes, as long as you turn “Scene Detection” off in Capture prefs.
    If this is ON, it will split capture into separate scenes each time the camera was stopped/started, assuming the camera clock had been set.
    Peter Wright
    Perth, Western Oz
