Activity Forums Apple Final Cut Pro Legacy odd keying??? help needed
  • odd keying??? help needed
    Posted by Sean Morton on May 27, 2009 at 3:00 am
    Hi
    i am using final cut pro 6 with keylight
    After the image is keyed out
    and cropped, i have an image of someone
    speaking in front of a black screen from
    the chest up. At the top of the viewable
    black screen there is a line that looks like it comes
    from the bottom of the the person. the length
    of their chest.
    almost like the last line of image is taken
    from the bottom and put to the top of the viewable
    screen area..and it ends up rendering out like this.
    it doesn’t happen all the time with other keyed out
    images and it sometimes occurs in other locations
    but seems to take place when i am keying. This one
    displaced line which is horizontal at the full or cropped
    edge of the screen.
    I am absolutely stumped.. Sorry for the explanation
    i hope you are able to picture what i was trying
    to get across.
    John Fishback
    replied 17 years, 4 months ago
    2 Members · 3 Replies
  • John Fishback
    May 27, 2009 at 7:14 pm
    Have you tried to crop that line? If so, what happens? Is that line in the key layer, the background or another layer? I have used Keylight in AE, but not the FCP plugin.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Sean Morton
    May 27, 2009 at 7:44 pm
    Yes i have.
    the line is at the bottom of the cropped frame.
    It isn’t there with the regular footage before it
    hasn’t been keyed out.
  • John Fishback
    May 27, 2009 at 8:46 pm
    If you try to crop, does the line just move with the crop? Maybe if you nest the key and then try to crop the nest you can get rid of it. Have you looked at the various matte views to see if you can identify where in the process the line is coming from? I’ve never seen this. Hopefully, someone else might have an idea.
    John
