Activity Forums Adobe Premiere Pro Odd DVD Burn Error…
  • Odd DVD Burn Error…
    Posted by Dandan on November 4, 2006 at 12:02 am
    Hey all,
    Been burning DVD’s out of PP2 just fine, though the other day it suddenly stopped working…halts the burn and gives me this error:
    runtime error: use of invalid editor
    “AuthorCore::SegmentEditorBase”
    Any ideas?
    -Dan
    Robert Shank replied 17 years, 2 months ago 3 Members · 3 Replies
  • Tcindie
    November 4, 2006 at 6:09 am
    So far as I can tell, from a little searching on various forums, it’s an issue related to start and stop markers. (And primarily only on DVDs with multiple episodes?)
    You might want to try exporting an MPEG-2, and burning with a different program. While that’s not the best fix, it would at least be a usable workaround. Apparently Adobe has not yet posted an official workaround method.
  • Dandan
    November 5, 2006 at 6:36 am
    Thank you!
  • Robert Shank
    July 15, 2009 at 12:14 pm
    I got the same error message and when I was reading the response about menu and stop markers, I was able to solve the problem.
    First of all, I erased a couple of markers and replaced them in. Plus, I do not think I had a menu marker at the beginning of my project. You need to have a menu somewhere (makes sense). The menu marker is green! Make sure you go to the beginning of your project and place a menu marker there. If you follow this…it should solve your problem!
