Activity Forums Adobe After Effects Odd compression behaviour…
  • Odd compression behaviour…
    Posted by Mark_c on August 31, 2005 at 9:41 am
    Hello, I have been given a file which is 265Mb. The file is 1024×768, Thousands of colours, and Video compression (according to Quicktime player).
    I have then imported this into After Effects, reduced it’s size to 800×600, and then recompressed using Video compression and the final file size comes out at 447mb.
    How can this be? I would have expected the file size to be about 0.6 of the original size!
    Mark
    Steve Roberts replied 20 years, 12 months ago 3 Members · 3 Replies
  • Spaceman
    August 31, 2005 at 9:46 am
    spaceman wonders if the original was unmatted and the the second premultiplied?
  • Mark_c
    August 31, 2005 at 9:54 am
    The movie has no alpha, so I don’t think that matters, or am I missing the point?
  • Steve Roberts
    August 31, 2005 at 1:00 pm
    You may be recompressing at a higher data rate than the original, making a bigger file as a result.
    Try reducing the quality of the compression in the Options dialog, and inputting a number into the keyframes box. Try 15, 30 maybe. It’s a bit of an art.
    Steve
