Activity › Forums › Avid Media Composer › Odd Blue Screen During Component Capture
  • Odd Blue Screen During Component Capture
    Posted by Mark Crenshaw on July 29, 2009 at 8:44 pm
    Nitris DS, XW8400, Avid MediaRAID 2.5TB, XPPro SP2, MC3.0
    We normally use the SDI input on our Nitris but I have several BetaSP tapes that I need to capture from. When I select the Component setting in the Capture tool, this is what I see:
    I have checked all cables, restarted everything, checked settings in the capture and media creation tabs…nothing seems to change it. SDI, Composite and Y/C are all fine. Component seems to be the only input that has this problem.
    Any ideas what might be causing this?
    Peace,
    Mark
    Mark Crenshaw replied 17 years, 2 months ago 2 Members · 2 Replies
  • Michael Hancock
    July 29, 2009 at 9:02 pm
    Check that the component outs of your Beta are correctly run into your Nitris box (did someone run Y to R, for example?). It they’re run right, swap out the cable to see if it’s bad.
    Otherwise, not really sure.
    Michael
    I’ll be working late.
  • Mark Crenshaw
    July 29, 2009 at 9:27 pm
    Hi Michael. Thanks for the quick reply.
    I’ve double checked all the connections but no change. I switched from our PVW-2800 to our BVW-75 and it’s fine now…may be something in the back of the patch panel in the PVW-2800 connections. At least it’s not the Nitris. Whew!
    Peace,
    Mark
