Activity › Forums › Apple Final Cut Pro › Odd Audio Behavior
  • Odd Audio Behavior
    Posted by Michael W. towe on May 2, 2013 at 7:22 pm
    So I have an interviews that I am cutting and I am going it in a compound clip because it will get placed in multiple timelines. The audio is 4 channels of Mono, which I am killing 3 of, and just using the best channel. I drop an EQ and compressor on it and set the level to average at -20db all is good. Now when I drop that compound clip into a project I find that the audio now has to be boosted by 5db to get back to the average -20db that I had in the compound clip. Any ideas why levels in a project would be different from the compound clip?
    And for extra credit… My broadcast specs call for a peak audio level of -12db. No problem right? Just drop a limiter and set it to -12db. But hold on, the limiter in X only lets you limit down to -10db. Any one know how to get the limiter down to -12db?
    Michael W. Towe
    President M2 Digital Post
    http://www.m2digitalpost.com
    Michael W. towe replied 13 years, 4 months ago 2 Members · 2 Replies
  • Nick Toth
    May 2, 2013 at 10:37 pm
    I can’t replicate your compound clip problem. If I set levels, compound and then copy the compound into another project the levels are consistent.
    I would edit the interview in a project and then compound the completed edit and copy/paste into the other projects.
    As far as your limiter question, you should be adjusting “gain” which goes down to -20. Where you set that depends on what the level of the audio is in the first place. There can be interaction between the different settings.
    anickt
  • Michael W. towe
    May 3, 2013 at 12:49 am
    Hey Nick,
    Thanks for the response. Just a follow up from my end…
    So at first I thought it might be a workflow issue as I was creating an empty compound clip and then editing the footage into it. Then I was applying the compressor and adjusting it, then dropping the compound clip into a project. As explained I we having to bump the audio by +5db to get the levels to match.
    You were suggesting create a project, then edit the footage in, add and adjust the compressor and then compound clip it. If I do this the exact opposite happens. Now I have to drop the audio in the compound clip to get it to match. But wait it gets better… If I don’t drop the level of the compound clip, but drop it back into a project the levels are now back to where I set them, even though the compound clip is +5db hotter. Confused yet?
    In short, I have a consistent 5db mismatch from compound clip to project. Which way that miss match is depends on when I created it. If created in a compound clip and dropped into a project, the project is -5db. If created in a project and compounded, the compound clip is +5db
    I have tried this on 2 system here at my shop and it behaves the same way on both. I would love another data point on this if someone else wants to give it a shot.
    Michael W. Towe
