Activity Forums VEGAS Pro Observing that MPEG2 Video for DVD rendering times are a lot slower in Vegas Pro 11
  • Observing that MPEG2 Video for DVD rendering times are a lot slower in Vegas Pro 11
    Posted by Derek Moran on November 5, 2011 at 3:34 am
    So I just posted a message about Windows Media Video (.wmv) not rendering at the same speeds that Vegas Pro 10 could do. So after discovering this, I thought I better check out another rendering profile that I use quite a bit – MPEG2 for DVD.
    There is definitely something wrong big time, with the Vegas Pro 11 rendering engine for MPEG2.
    I did a series of comparison experiments using a 10 minute clip of 1080-60i AVCHD video straight out of the camera, rendering it to MPEG2 720×480 Widescreen NTSC Video.
    *Test One: Vegas Pro 11 (425) with GPU assist in Video-Preferences turned ON.
    Total time to render = 27 minutes !
    During this time, only about 20% of my i7-2600k CPU was being utilized.
    *Test Two: Vegas Pro 11 (425) with GPU assist in Video-Preferences turned OFF.
    Total time to render = 21 minutes.
    Once again, very low utilization of my CPU – about 30%
    *Test Three: Vegas Pro 10e
    Total time to render = 4:28 minutes !!!
    100% of my CPU was being utilized during this render.
    When I built my new i7-2600k machine 6 months ago, Vegas Pro 10 was performing better than I could have dreamed of. My rendering times were just a joy to see. I was really looking forward to using Vegas Pro 11, but appears that we will have to wait a little while longer until the “bug infestation” is removed.
    I have reported this to Sony Creative Software.
    Has anyone else noticed this rendering problem yet?
    Once again, I am on a completely new machine with all the latest drivers and updates installed.
    On a positive note, Main Concept AVC rendering times are now lightning fast on Vegas Pro 11 – can’t wait until the rest catch up.
    My PC Specs:
    CPU: Intel i7-2600k @ 4.6 GHz
    GPU: Nvidia GTX460
    RAM: 16GB Corsair Vengeance
    Boot Drive: 120GB Solid State Drive
    Storage: 2 x 1TB Hard Disc Drive
    Sound Card: Creative Soundblaster X-Fi Titanium
    Mark Barton replied 14 years, 10 months ago 3 Members · 2 Replies
  • Dave Haynie
    November 5, 2011 at 7:59 am
    Sure sounds like a fast system, when things line up. I tried the same experiment: 10 minutes of AVCHD, direct from the camcorder (Panasonic HMC40, PH-mode, 1080/60i), rendered to the Main Concept Widescreen NTSC DVD template. This is rendering from my 3TB D: drive to my 1.5TB C: drive. This is actually the first time I ran Vegas 11.425… used the original extensively over the last few weeks. DRAM Preview is 1GB, tested with 64-bit Vegas, Windows 7 SP1.
    Vegas 11 w/GPU, proj: HD 1080-60i, quality=good, pixel=8-bit.
    time = 7:23 CPU = 65% GPU = choppy (peak at 31%)
    Vegas 11 w/GPU, proj: HD 1080-60i, quality=best, pixel=32-bit(vl)
    time = 7:02 CPU = 65% GPU = 38%
    Vegas 11 w/GPU, proj: NTSC WS DVD, quality=best, pixel=8-bit
    time = 8:13 CPU = 65% GPU = choppy (peak at 26%)
    Vegas 11 no GPU, proj: HD 1080-60i, quality=good, pixel=8-bit
    time = 7:39 CPU = 92%
    Vegas 11 no GPU, proj: HD 1080-60i, quality=best, pixel=32-bit(vl)
    time = 15:02 CPU = 98%
    Vegas 11 no GPU, proj: NTSC WS DVD, quality=best, pixel=8-bit
    time = 9:43 CPU = 95%
    Vegas 10 no GPU, proj: HD 1080-60i, quality=good, pixel=8-bit
    time = 7:26, CPU = 85%
    Vegas 10 no GPU, proj: HD 1080-60i, quality=best, pixel=32-bit(vl)
    time = 26:30, CPU = 50%
    Vegas 10, no GPU, proj: NTSC WS DVD, quality=best, pixel=8-bit
    time == 22:31, CPU = 40%
    My PC Specs:
    CPU: AMD 1090T @ 3.2 GHz
    GPU: AMD Radeon HD6970
    RAM: 16GB DDR3 Kingston HyperX PC3-12800
    Boot Drive: 1.5TB Seagate 7200RPM
    Storage: 3TB Internal, 2TB in drive slot, 8TB Drobo
    -Dave
  • Mark Barton
    November 5, 2011 at 8:14 am
    I saw the opposite, but I may be limited by the drives. The CPU/Coress (all 12 in task manager) were running at 80+%
    It took 19m:12s within version 10e and 17m:35s in version 11 build 425.
    10 min 1920×1080/60p native file
    i7-970
    Nvidia GTX 570
    12GB
    Source on second sata drive and rendered to OS drive.
