Activity › Forums › Boris FX Particle Illusion › Observation-Could be a problem in rare cases
  • Observation-Could be a problem in rare cases
    Posted by Aaron Cross on December 26, 2010 at 1:21 am
    Hi
    I used external extra monitor fo PI because it was bigger, later I disconnected it and started Particle Illusion, but PI still wanted to host the program on the (now detached) extra monitor.
    Try this:(On Mac)
    Use extra monitor
    Drag PI over there.
    Quit PI
    Detach extra monitor
    restart PI
    > Can you actually get it to appear on the main screen? I couldn’t.
    Could be really bad news if it was crunch time and it was located offscreen. I guess I’d try deleting the prefs file for a start.
    HTH
    Cheers
    AaronC
    Alan Lorence replied 15 years, 9 months ago 2 Members · 1 Reply
  • Alan Lorence
    December 28, 2010 at 2:27 pm
    This is a known problem. I think deleting the prefs file should fix it, but if you can verify that when you get a chance that would be helpful.
    Alan.
    http://www.wondertouch.com
