Activity Forums VEGAS Pro Obscured Wipe Transition
  • Obscured Wipe Transition
    Posted by Alex Ivanov on May 31, 2018 at 11:24 pm
    How do I make an “Obscured Wipe Transition” or whatever it’s called? It’s widely used in “My name is Earl” tv series, like here: https://youtu.be/7_ArE_IinnM?t=30s (start at 30 second). Thanks!
    Francois Pénzes replied 8 years, 3 months ago 3 Members · 5 Replies
  • Paul Berk
    June 1, 2018 at 2:41 am
    First you just cut to a black screen .. the use the “slide” transition.
  • Francois Pénzes
    June 1, 2018 at 11:00 am
    Hi Alex
    The other way to do this is to add the Push transition to the overlap of your 2 clips.
    Step 1
    Step 2
    You can play with the size of your black. I also noticed that the referenced clip had soft edges. Just use the Feather option but no more than an setting of 7.
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 14, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Alex Ivanov
    June 1, 2018 at 8:07 pm
    Paul Berk, thank you, it seems that this is what I need!
  • Alex Ivanov
    June 1, 2018 at 8:09 pm
    Francois Pénzes, it’s not exactly what I need, following your example, my result is the clips themselves are moving, not the “obstacle” between them.
  • Francois Pénzes
    June 2, 2018 at 2:30 am
    Hi Alex
    Well that’s what it does in your example…or close, it actual fact, there is a camera pan on top of the blackened effect. At least you got some options out of it.
    Cheers !
