Activity Forums Maxon Cinema 4D OBJ’s imported into Cinema are too shiny!
  • OBJ’s imported into Cinema are too shiny!
    Posted by Rolf Tollerud on September 12, 2015 at 12:29 pm
    Whether there is a mtl file or not, they all look the same. What can I do to make the “default render” more like a Keyshot render?
    Rolf Tollerud replied 11 years ago 3 Members · 3 Replies
  • Adam Trachtenberg
    September 12, 2015 at 7:32 pm
    Cinema’s native obj. import doesn’t read mtl files. Add your own material to the object.
  • Brian Jones
    September 12, 2015 at 7:57 pm
    R17 does read .mtl files, I don’t import enough .obj to know how good it is but it seems to work for the few I’ve tried.
  • Rolf Tollerud
    September 12, 2015 at 10:22 pm
    Thank you Adam, for reminding me of C4D own obj import/export which I have not used for years. Since c4d 11.5 in fact. Actually it imports correct! The error is in Riptide. With Riptide I can import an obj file with the specular set to,
    Ks 0.000000 0.000000 0.000000
    Ns 5.000000
    And yet the component has unwanted specularity after import. Moreover, if I export with Riptide ganz richtig I now have,
    Ks 1.000000 1.000000 1.000000
    Ns 50.781250 In the mtl file.
    And there is no way I can get rid of it inside c4d even if I uncheck the whole Reflectance parameter.
    But – I can use c4d’s obj import. I suppose it is safe now after so long time. Or do you know about any issues with it?
    I am really ashamed that I have not discovered the error in Riptide before now. I observed it but thought it was nothing to do.
    Oh well..
