Activity › Forums › VEGAS Pro › Objects upon render are shifted from project
  • Objects upon render are shifted from project
    Posted by Ohki Komoto on August 6, 2010 at 3:27 pm
    Hey there fellow Vegas users,
    I’ve been using Vegas awhile, and it’s by far my favorite editing program and never had a problem until now. I am finishing up a DVD presentation for work that involves pointing arrows and such on graphs among highlighting segments. The typical seminar type deal.
    In my project/ pan crop window, the arrows are fine. They’re fine in the playback in the timeline, but after rendering, the arrows are shifted slightly to the right…..which ruins the whole presentation.
    Anyone have ideas on what could be causing this, and how to resolve this issue….other than calibrating all the arrows for the unwanted shift. This video is over an hour, and is straight from the president of the company I work for so it would very helpful.
    I could use any feedback/suggestions/solutions
    Many Thanks
    O
    Ohki Komoto replied 16 years, 1 month ago 3 Members · 5 Replies
  • Mike Kujbida
    August 6, 2010 at 4:25 pm
    Make sure your Preview window is set to Best/Full when you’re lining up your arrows.
  • Ohki Komoto
    August 6, 2010 at 7:11 pm
    It is on full, and even full screen on a 2nd monitor for double checking. Still no avail though some are rendering correctly so there must be some difference I am failing to see. Maybe I have tried to match output aspect or source aspect somehow which I don’t reccall.
  • Danny Hays
    August 7, 2010 at 3:37 am
    Yes your right. I had that problem before when I rendered drom 1440 x 1080 to 720 x 480. Try rendering to a lossles, but same resoultion and aspect ratio, then render that to the other size. Hope this helps, Danny Hays
  • Ohki Komoto
    August 9, 2010 at 3:01 pm
    Sounds logical.
    I’ll give it a shot. S
  • Ohki Komoto
    August 9, 2010 at 3:35 pm
    No luck.
    I’ve tried several things, changing settings in the pan crop and matched the resolution as Danny suggested.
    Oh why can’t it be what you see is what you get on the timeline lol.
    Well I haven’t figured out what is wrong yet, but that’s part of the learning process sometimes….when you find a solution. Otherwise its just a problem.
    I think I might try restarting on these arrows again, and start fresh.
    If anyone has any other ideas, i’ll be checking.
    Thanks again!
