Activity Forums Maxon Cinema 4D objects shooting away when made dynamic?
  • objects shooting away when made dynamic?
    Posted by Thomas Pascavage on December 29, 2011 at 6:18 pm
    this is odd and i cant seem to refigure it out. when i first got c4d, i did this crazy rube goldberg sorta thing with a sphere rolling down a ramp, then into a sweep nurb which i turned into a tube and it followed this crazy path to an end. i remember giving all the objects dynamics, and turning them off on everything except the sphere. i tinkered with it for a bit to get the aim right, but i dont recall messing with the settings. other than eliminating the gravity via the on/off/ghost switch. now im trying to do a gumball machine, and when i put the sphere into the box with the holes to dispense then hit play, it shoots out at the speed of light completely ignoring the collision dynamics. any help? i have the project if that helps
    Thomas Pascavage replied 14 years, 7 months ago 2 Members · 2 Replies
  • Brian Jones
    December 29, 2011 at 6:44 pm
    probably you have Shape set to Automatic or Automatic(MoDynamics) you probably need to set it (them) to Static Mesh or Moving Mesh depending on whether the object is moving or not. Depending on shapes this applies to the Rigid objects and the Collider objects
  • Thomas Pascavage
    December 30, 2011 at 4:54 am
    bingo, thts exactly what was wrong. appreciate it
