Activity › Forums › Maxon Cinema 4D › “Object’s shadow buffer” !!!
  • “Object’s shadow buffer” !!!
    Posted by Platon Infante on September 16, 2018 at 9:52 am
    Is it possible to render separately (multipass) the only shadow from exact object?
    For example: there is shadow from the figure on the stairs, which itself has its own shadow. I need to have the image of only shadow from figure to adjustment it separately (in non realistic way).
    Platon Infante replied 8 years ago 2 Members · 2 Replies
  • Steve Bentley
    September 20, 2018 at 4:34 am
    I think you could do that with a shadow catcher object (a copy of the stairs) and assign an object buffer to this copy. Remember to put a compositing tag on the stair object so it doesn’t cast shadows itself.
    In R17 and higher the shadow catcher shader is built in. But before that there is a free add on that you apply to the transparency channel of the material on your shadow catcher object.
    Here’s the old version https://www.thepixellab.net/cinema-4d-free-shadow-catcher-plugin
  • Platon Infante
    September 23, 2018 at 10:14 am
    Thank you for response, Steve! I will try this.
