Activity Forums Maxon Cinema 4D Objects seen (not seen ) bey different cameras
  • Objects seen (not seen ) bey different cameras
    Posted by Lothar Wieland on October 21, 2014 at 12:03 pm
    Hello, how can i achieve in an archtectural scenery to make an selection of objects which are seen or not to be seen by different cameras. I understand the compositing tag only referres to the active camera…, i will switch between cameras and do not want f.e the same object is seen by each different camera. I want this to differentiate. Does anyone has an idea how to get this done? Lothar
    Pierre Fossey replied 10 years, 4 months ago 3 Members · 3 Replies
  • Emir Bojorquez
    October 23, 2014 at 3:21 pm
    Here is a simple Xpresso Rig:
    -Use the “Camera Number” control, to move from camera to camera
    – To add or remove cameras go inside the Xpresso tag and select the “Cameras” Node.
    – To go back to the perspective view Uncheck “Cameras On/Off” and then deselect the camera as always.
    *-Objects Visibility: The Order of each object corresponds to the order of each camera
    I hope this helps.
    8129_seenbyrig.zip
    Good Luck
    Imagination is the best tool…
  • Lothar Wieland
    October 23, 2014 at 4:34 pm
    Thanks for sending this fine xpresso Rig. Works excellent. Exactly what i wanted to control.
  • Pierre Fossey
    April 22, 2016 at 8:37 am
    Hi Emir,
    i just find your post and it’s actually a great way to do the job !
    I wanted to know if it’s possible to enable this function in render queue too, when i select a camera in the render queue, it would be great to enable the object in the pool, any idea of how to ?
    thanks,
    Pierre
