Activity Forums Adobe Illustrator Objects jumping after releasing mouse
  • Objects jumping after releasing mouse
    Posted by Chris Svensson on October 20, 2011 at 8:23 pm
    Hello all,
    I hope I can explain this without the benefit of video… I just started having a weird problem in Illustrator CS5. When trying to do some precise placement of objects and points, I notice that the objects/points are moving slightly from where I intended. For example, I am trying to place the end point of a line on top of the end point of another line. I am zoomed in all the way, I drag the point into JUST the right place, smart guides are on and read “intersect”—in other words, it’s locked in, right in place. Then, when I release the mouse button, the point jumps diagonally up or down a few clicks. It’s really weird too, because sometimes it will jump say, up and to the left, sometimes down and to the right. The only constant is that I can’t place things where I want them. It is driving me nuts!
    Has anyone else had this problem? I have tried everything. Smart guides on/off, all the guides are off, snap to point, snap to grid, etc. all off. I have deleted my preferences and .plist and restarted… This is version 15.0.2 and I don’t think there is an update available.
    Any help or advice you could offer would be greatly appreciated. Thank you so much in advance!
    Adam Boden replied 9 years, 10 months ago 9 Members · 9 Replies
  • 9 Replies
  • Vincent Rosati
    October 24, 2011 at 2:15 pm
    Initially I thought it might be ‘Snap to Grid’, but you said you checked that.
    I don’t have any other thoughts. I’m not sure. I guess I was just wondering if you’ve made any progress with this issue?
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Chris Svensson
    October 27, 2011 at 5:44 pm
    Yeah, snap to grid wasn’t the issue.
    I just figured it out. There is a check box on the Transform panel that was set to “Align to pixel grid.” That solved it. Thanks!
  • Abel Giordano
    October 18, 2012 at 2:00 pm
    Be Blessed!
  • Alonso Colmenero
    March 13, 2013 at 10:35 pm
    You sir, just saved me days of pulling hair and cursing at the computer.
  • Santiago Dutil
    September 18, 2014 at 8:16 pm
    Thanks!!
  • Piotr Mossakowski
    November 24, 2014 at 8:06 am
    Thank you mate! Problem solved!
  • Ariel Ayres
    April 11, 2016 at 1:06 pm
    I created an account just to say that YOU SOLVED MY 2016 PROBLEM JESUS CHRIST! Thanks thanks thanks thanks thanks
  • Jacob Peñaloza
    October 25, 2016 at 11:38 pm
    THAAAAANKS!!!
  • Adam Boden
    November 2, 2016 at 6:26 pm
    I’m having this same issue, but turning off align to pixel grid did not solve it. It’s frustrating because the projects I’m currently working on are often several feet long, so I can’t tell if my graphics are off my artboards unless I zoom ALL THE WAY IN, which adds significant time to my workflow.
    Any additional suggestions / solutions would be very much appreciated.
