Activity Forums Maxon Cinema 4D Objects follow contour of another object
  • Objects follow contour of another object
    Posted by Rachael Balascak on June 2, 2011 at 8:59 pm
    Hello,
    I am simply trying to get sprinkles to lay on the contour of a donut. I created my sprinkles by putting a capsule in a cloner object.
    Can someone point me in a direction please…thanks!
    Rachael Balascak replied 15 years, 2 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    June 2, 2011 at 10:18 pm
    Create a polygon selection where you want the sprinkles. Set the cloner to object mode and refernce the donut. Drop the selection tag into the Cloner’s selection box to restrict the sprinkles. Set the distribution mode to surface. Use a random effector to vary rotation. Brew some coffee and away you go.
  • Rachael Balascak
    June 3, 2011 at 12:16 am
    Thank you soooo much! That worked perfectly!
    -rachael
  • Tony Barone
    June 3, 2011 at 4:26 pm
    I’m curious as to how you did the “icing”?
  • Rachael Balascak
    June 22, 2011 at 11:51 pm
    I made a material and used the pic below as the texture, to give it an alpha, made the color white and gave it a bump to looked raised.
    -rachael
