Activity › Forums › Maxon Cinema 4D › Objects: expanding
  • Objects: expanding
    Posted by Kelly Johnson on February 1, 2007 at 11:19 pm
    I have an imported 3ds file. Though most pieces are separate objects (have the blue triangle icon) some pieces which are part of different objects seemed ‘grouped.’
    When I select object info, it gives the poly count and such and says 1 object.
    So, am I stuck with both pieces that make up that one object?
    Example: I have two buildings. On the left is a house and a part of the porch is somehow grouped/related to the window trims of another building further away in space.
    I’ve tried to break them apart, delete texture tags, the polygon selection tags but I can’t seem to delete one without losing the other.
    Just wondered if there is anyway to delete one piece of an object.
    Mylenium replied 19 years, 8 months ago 2 Members · 1 Reply
  • Mylenium
    February 2, 2007 at 6:44 am
    Functions –> Explode Segments.
    Mylenium
    [Pour Myl
