Activity Forums Maxon Cinema 4D Objects disappearing once editable
  • Objects disappearing once editable
    Posted by Scrambledpotatoes on August 31, 2007 at 2:14 pm
    I’m using Cinema 4D version 10.102 with Warp 10, BodyPaint 3D, and MoGraph installed.
    The problem I’m having is whenever I have a polygon object in the editor, and I make that object editable, it disappears in the editor. It’s still in the layer view, and when I render that frame, it shows up. If I use the select tool, select points that would be there and move them, that shows up in the render, but once again, not in the main view.
    I’ve tried texturing, changing display settings (shading, wireframe, isoparms) nothing is helping it.
    But, if I import a co-worker’s project it isn’t a problem.
    We’re at a loss, can anyone help?
    Arndt Von koenigsmarck replied 19 years ago 2 Members · 4 Replies
