Activity Forums Maxon Cinema 4D Objects coming out of container using dynamics
  • Objects coming out of container using dynamics
    Posted by Brian Mills on March 12, 2015 at 1:20 pm
    I am working on these dropping pill bottles got it to work pretty good with some help. Now I am noticing that some of the pills are coming out the of the bottle when they hit the ground. Any ideas?
    8646_newstudio.c4d.zip
    Brian Mills replied 11 years, 6 months ago 3 Members · 3 Replies
  • Martin Pedraza
    March 12, 2015 at 2:00 pm
    I’m a complete noob, buy i saw a solution for this some time ago in a tutorial. There is a selection tool for cloners, which lets you select certain clones and disable them.
    The part i’m speaking about is 10 minutes in.
    https://vimeo.com/101572223
  • Brian Jones
    March 12, 2015 at 8:42 pm
    in Mode/Project/Dynamics/Expert increase Steps per Frame. I increased to 10 in a quick test and that stopped it but it may work with fewer steps and be quicker to solve. I also changed the Pills dynamic shape to be Automatic – it was quicker that way and worked a bit better.
  • Brian Mills
    March 12, 2015 at 8:57 pm
    Thanks for the help I upped it to 25 and it works…
