Activity Forums Maxon Cinema 4D Object warping when rendering
  • Object warping when rendering
    Posted by Roni Selovuo on December 9, 2019 at 7:54 pm
    Cannot find the problem from my layers to avoid weird warping of the object when im rendering it out (animation)
    Theres my layers and here you can see the warping in those explosing parts.
    https://youtu.be/eY5oTxwdwz8
    So where i probably find the solution?
    Roni
    Roni Selovuo replied 6 years, 9 months ago 3 Members · 3 Replies
  • Sam Treadway
    December 10, 2019 at 5:17 am
    It appears you have a noise-based displacement on the material. Is that noise projected in World space? If so, try switch to Texture space.
  • Steve Bentley
    December 11, 2019 at 5:55 pm
    And check that the “Speed” of the noise is set to 0.
  • Roni Selovuo
    December 13, 2019 at 9:52 am
    Thank you so much! that was the issue actually, BIG thanks.
