Activity Forums Maxon Cinema 4D Object visible in viewport, doesn’t show up in render?
  • Object visible in viewport, doesn’t show up in render?
    Posted by Caroline Anthony on January 20, 2016 at 3:14 pm
    Hey guys,
    I have the strangest problem. My object shows up in my viewport, but not in my render. It only happens in certain frames with no rhyme or reason. I’ve uploaded a scene file – if you look at frames 126-128, the object is visible in the viewport but not the render. I assume it has something to do with the boolean but I’ve found no viable solution. I’m in C4D R17. Any help appreciated!
    9685_liquidissue.c4d.zip
    Caroline Anthony replied 10 years, 4 months ago 1 Member · 1 Reply
  • Caroline Anthony
    January 20, 2016 at 7:04 pm
    Apparently all I had to do was uncheck ‘High Quality’ under the object properties of the boolean.
