Activity Forums Maxon Cinema 4D object visibility during animation
  • object visibility during animation
    Posted by Jason Stirret on May 17, 2011 at 10:35 am
    Lots of questions lately! I am working on an animation in which I want to make an object visible perhaps a hundred frames into it. I use a pBlurp to change a chunk of steel into a text object…when the PBlurp has run it course I want it to explode out from the force of the particles that created it. Does anyone know how to turn on the original text object (which is turned off so the pblurp can run) i.e. make it re-visible so that I can explode it. Perhaps it would be easier to use a separate object altogether. In which case how do I make it visible part way into an animation? Tags? Xpresso? Any suggestions?
    Tim Shetz replied 15 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Adam Trachtenberg
    May 17, 2011 at 2:06 pm
    I would use two objects. You can keyframe visibility several ways. If you just want the object to appear/disappear in a single frame the easiest way is to keyframe the “visible in renderer” parameter in the object’s Basic tab (the lower traffic light dot). If you want to animate an object fading in/out, give the object a display tag and animate the visibility parameter. Of course you can also animate material transparency or alpha. And lastly, you could simply animate the object so it moves behind, or from behind, the camera in a single frame.
  • Jason Stirret
    May 17, 2011 at 11:55 pm
    Thanks Adam…Its guys like you who give hope to guys like me that perhaps someday I will threaten to almost understand what I’m doing with this stuff (wink). Are there classes you can take…Cineversity?
  • Tim Shetz
    May 18, 2011 at 2:00 am
    Where are you located? There are a few classes around.
    __________
    Tim Shetz
    c4dtraining.com
  • Jason Stirret
    May 18, 2011 at 3:49 am
    Ellensburg WA, Central Washington University! Cows and school (no pun intended)
  • Adam Trachtenberg
    May 18, 2011 at 1:17 pm
    Cineversity is a great resource. Lynda.com also has good Cinema content. There are also some personal tutors who will give lessons remotely via screen sharing.
  • Tim Shetz
    May 18, 2011 at 4:23 pm
    There are a few Cinema 4D classes being offered in the Bay Area in July and August. I know it’s in San Francisco, but it’s not a bad place to visit:
    Intro to Cinema 4D July 16-17
    Intro to Cinema 4D August 6-7
    Cinema 4D Intermediate August 20-21
    __________
    Tim Shetz
    c4dtraining.com
  • Tim Shetz
    May 18, 2011 at 4:24 pm
    There is also my site: C4DTraining
    __________
    Tim Shetz
    c4dtraining.com
