Activity Forums Zaxwerks Object transparency in ProAnimator
  • Object transparency in ProAnimator
    Posted by Kenny Mims on June 14, 2005 at 3:57 pm
    Is it possible to change the transparancy of an object “as she runs” in ProAnimator.
    Visualize with me if you will: a circle around an overlapping cube – circle rotates one way, cube rotates the other…but fades out (while rotating). I can do this using 2 similar renders (one all circle + one w/ circle & cube) and fade between them in AfterEffects, but the ‘smashing into each other’ portions are not quite right. Is there another way?
    Thank you all so very much!
    KM
    Matt Rhodes replied 21 years, 3 months ago 2 Members · 1 Reply
  • Matt Rhodes
    June 14, 2005 at 4:00 pm
    Hi Kenny.
    The next version of ProAnimator, version 4.0, will have some controls to make fading in and out easy.
    Stay tuned.
    Matt Rhodes
    Zaxwerks, Inc.
