Activity Forums Maxon Cinema 4D Object Tracking Help
  • Object Tracking Help
    Posted by Kevin Camin on April 30, 2021 at 5:38 pm
    Need some help here from you smart people.
    I’m farming out some tracking work––please see the video. On the left is the shot that will appear in the video, on the right is a second camera to potentially help with the track. What we are trying to do is attach a cape to the actor. The actor is going to turn into a full CG character pretty quick in the shot, so essentially we just need to track the actor so we can overlay a CG version of him that we will stick the cape on and then make the CG character invisible until it’s time for the transition from live action to full CG.
    What is the best way to get this track? I’m working with someone who uses PFTrack and they are saying they can’t track it because the camera isn’t moving but they should be able to manually set up the room and then object track, can’t they?
    Looking for any and all ideas! Thank you so much.
    Kevin Camin replied 5 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
