Activity Forums Adobe After Effects object scales while rotating
  • object scales while rotating
    Posted by Dom Gomes on November 26, 2013 at 4:04 pm
    When I am rotating an object in after effects cs5 it also scales. How do I correct this? I made a clock and clock hands in illustrator imported them into after effects, I moved the anchor point to the bottom of the clock hand and then when I start to rotate the hands they scale all weird. Please help.
    Dom Gomes replied 12 years, 9 months ago 3 Members · 3 Replies
  • George Goodman
    November 26, 2013 at 6:33 pm
    So it is actually enlarging the hand, or is it just not rotating around the clock as you want?
    If it just isn’t rotating properly, make sure that you didn’t just set the anchor point of the whole layer, but that you set the anchor point of that particular shape as well.
    If it is physically enlarging, check to make sure you didn’t enable any expressions.
  • Ridley Walker
    Check the pixel aspect ratio of the Composition, from the Composition menu select Composition Settings, make sure the PAR is square pixels.
  • Dom Gomes
    November 27, 2013 at 4:22 am
    Changing the Pixel aspect ratio to square pixels was the solution for this situation. I have also had this problem in a character animation when layers are linked. When I rotate an upper arm, the lower arm (which is linked to the upper arm) in the chain scales all weird in a square pixel aspect ratio. Any help would be appreciated. Thanks again for your help.
