Object removal in moving video (use Clone Stamp or Roto Brush?)
Hello,
I’ve been having a really difficult time trying to remove objects from moving clips. I’m attempting to remove the head off of the right most statue, but cannot find an effective way to do this… When I use the clone stamp, it tracks, but I cannot get it to blend in realistically, seeing as the color of the sky changes as the clip pans right. I also tried using a cut out image of the sky and tracked that, but that failed to blend as well…
If anyone has any suggestions for this problem, I would greatly appreciate it. I have this same issue with a couple other clips as well.
G
