Activity › Forums › Maxon Cinema 4D › Object passing a surface
  • Object passing a surface
    Posted by Jhonny Grazz on August 1, 2016 at 1:46 pm
    Hello guys,
    I got stuck on a project…I need this water drop to come out the water surface but I cant seems to get it right.
    I’m using C4D and AE with Cineware (I have some 3d Camera Track in use)….Basically I need to get rid of the ‘bulge’ but I need to keep the reflection (which I do with Compositing)
    But then I need to make the bottom part of the drop invisible if that makes sense? Because right now I can still see it…see attached
    Can’t get my head around this and I’m lost in the storm, anyone up to shed a light into this??
    Much appreciated!
    Adam Trachtenberg replied 10 years, 1 month ago 2 Members · 1 Reply
  • Adam Trachtenberg
    August 1, 2016 at 4:02 pm
    I’m not sure what’s available in Cineware, but if you have the Melt Deformer that might fit the bill. For more control you could use a mesh deformer or (if available) animated morphs.
