Activity Forums Apple Motion Object on end of a string – Cool Idea; How to Execute?
  • Object on end of a string – Cool Idea; How to Execute?
    Posted by Landon Satterfield on August 17, 2010 at 5:53 pm
    Hey guys,
    I have a question that’s not so much a pressured troubleshoot.
    i have a great idea but no where to start. Motion behaviors behave so violently inconsistent
    that I’ve lost a lot of trust in them.
    The idea is simple:
    I want to have an object (say, a rectangle) drop from the “ceiling” on a string that draws taught
    whenever the object reaches the end of the string. I want it to pop with some realism, causing
    the object to shake and spin.
    I’m thinking of when someone drops a necklace while still wrapped around one finger.
    That *snag* and sway that happens is what I am looking for.
    I appreciate you guys so much for your help. You are all awesome.
    Thank you for any advice you can give on behaviors and all things Motion.
    -LS
    Gareth Randall replied 16 years ago 4 Members · 4 Replies
  • Mark Spencer
    August 17, 2010 at 6:08 pm
    You might try the Spring simulation behavior to get started.
    Can you give an example of a behavior acting “violently inconsistent”? I’ve never seen that.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Stephen Smith
    August 17, 2010 at 6:14 pm
    Check out my Particle Party tutorial. I think it can get you a step in the right direction. Best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
  • Landon Satterfield
    August 17, 2010 at 7:15 pm
    Yeah, I can check out Spring, that’s a good idea.
    Has anyone ever made a physical string, that moved like one, in Motion?
    “violently inconsistent” or just not working at all despite parameters being adjusted.
    Quantize has never worked for me. I always result to a Strobe filter. In this instance
    it was pretty effective. I liked the result https://vimeo.com/14071790 – the black shapes.
    I’ll check out Particle Party for getting instructions on how to do this then tell you
    what I think. I haven’t had a chance to look at it yet.
    Thank you guys for your help!
  • Gareth Randall
    August 18, 2010 at 6:39 am
    [Landon Satterfield] “Has anyone ever made a physical string, that moved like one, in Motion?”
    It’s fairly straightforward to make a swinging pendulum out of a solid line, but do you want a string that will go slack or taut in a realistic way? If so, not sure how you’d do that in Motion without tediously having to hand-animate points on a Bezier shape.
