Activity Forums Apple Motion Object on a motion path follows a miniature version of the path instead???
  • Object on a motion path follows a miniature version of the path instead???
    Posted by Brian Dunning on March 6, 2017 at 5:14 pm
    OK this is really weird. I have been adding objets onto motion paths, no problem. All of a sudden the behavior has changed. I import the object, draw a bezier curve, and attach it to the object as a motion path, type Geometry. But instead of following the curve, the object follows a miniature version of the curve nearby. See the attached screenshot. You can see the white curve that I drew and attached, and you can see in red the miniature version of the curve that I did NOT create but that the object has decided to follow.
    Steps I’ve taken to debug: Deleted the objects and the curve, quit Motion, restarted, tried recreating them again from scratch. Same behavior. I hope my file has not become corrupted!!
    Brian Dunning replied 9 years, 6 months ago 2 Members · 3 Replies
  • Simon Ubsdell
    March 6, 2017 at 5:31 pm
    Have you accidentally disabled Attach to Shape?
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Brian Dunning
    March 6, 2017 at 5:45 pm
    No I thought of that — when I click it on and off, the (object + its miniature path) jumps between where it is shown here and the center of the screen.
  • Brian Dunning
    March 12, 2017 at 5:49 pm
    Just thought I would give the final disposition on this —
    I never figure out what was going on, and hacked a workaround by dragging my motion path really huge, off the page, to wherever it made my actual object go where I wanted it to go. That let me finish the project, which thankfully was short, and I won’t be using that file again. My guess is something was corrupt or triggered some obscure bug.
    Thanks for the help.
