Activity › Forums › Maxon Cinema 4D › Object not moving.
Object not moving.
Posted by An Wartersion on April 30, 2016 at 9:35 amHelp! i having a problem that only one object isn’t moving while everything else are moving just fine.
Amir Pasha replied 8 years, 9 months ago 4 Members · 7 Replies -
Jim Scott
April 30, 2016 at 2:48 pmMy first guess would be that you did not animate that one object properly. Without more information, which would hopefully include your project file, any help offered would just be more guesses.
An Wartersion
April 30, 2016 at 3:42 pmso here is the story, the object i was talking about has already animated, in the first few play the object moving just fine so i continue animated, after animated some more thing and i hit the play button that object just stop… i try to check the key frame, f-curves and everything still there but it won’t moving on the screen even after rendering, if you know the reason please help me.
Jim Scott
April 30, 2016 at 5:09 pmWithout seeing your project we would all be just guessing as to what the problem is. Post your project file and I will be glad to take a look at it when I get home later today.
An Wartersion
May 1, 2016 at 3:40 amHere is the file link https://f1.creativecow.net/10033/my-file-that-have-problem?uploaded=file
In this file an object name TopL used to control character mouth, but now it stop. -
Jim Scott
May 1, 2016 at 7:19 pmI found the object TopL in the expressions but as I am not well-versed in the use of expressions I will leave it up to someone else to help you out here.
Good luck.
Brian Jones
May 1, 2016 at 8:04 pmTopL drives the motion of 1, 1.5 and 2 but there is no animation of TopL (no keyframes) past frame ~1020 and the frame range you are showing us is 1100 to 1300 – it looks like it’s working fine before that and I can add keyframes after 1100 and get animation
Amir Pasha
November 19, 2017 at 3:33 amHi.. i don’t know if my problem is same as this…
I am not an expert.. i have rigged the character manually.. every thing was fine until i found that the left hand(L.Wrist) stops animating just for a duration of time. .. this time duration animation is not even rendering… i searched a lot but couldn’t find clue.. would be great full if some one could help.. Thanks in advance
