Activity Forums Adobe After Effects Object moving subtly after tracking footage- Element 3D
  • Object moving subtly after tracking footage- Element 3D
    Posted by Soham Jani on June 9, 2016 at 2:00 am
    I have a simple 3D .obj of a car I want to place in my footage. So, I 3D track my footage and create a new solid/null off of the tracking points (keep in mind my footage is mostly planar, like grass and some streets). Then I make a solid and add E3D with the car in it. However, during playback of my footage, I can see my car is moving a little off here and there for some reason in the footage while my solid is sitting in the grass just fine. Why is it doing this? How do I stop this?
    \”It\’s all around us Neo, temporary constructs of time…..\”
    Hanna Dean replied 10 years, 2 months ago 3 Members · 7 Replies
  • 7 Replies
  • Kalleheikki Kannisto
    June 9, 2016 at 6:12 am
    From your description it sounds like you applied Element to a 3D solid. It is not used that way.
  • Hanna Dean
    June 9, 2016 at 8:34 am
    1: remove 3d option from solid , aka 3d layer untick
    2: add object element 3d
    3: click solid layer /element 3d options / create group null 1
    paste tracking data to it .
    after effects manually tracking dont bother , use mocha
  • Soham Jani
    June 9, 2016 at 11:07 am
    Damn, you’re right. The 3D option was ticked. XD! I feel stupid now, but thanks anyway!
  • Soham Jani
    June 9, 2016 at 9:17 pm
    Well, I tried to make the car’s shadow by making a solid and making it 3D, and placing it under the car and now the solid moves a little. Why is it moving? And what’s a better way to make a shadow for the car?
  • Hanna Dean
    June 9, 2016 at 9:49 pm
    with elment 3d u dont use solid to make shadows , u use plate within the element 3d there is object in element 3d called plate or plane or floor ,
    youtube this
    element 3d shadow
    element 3d text shadow ul get the basic understanding and work from there
  • Soham Jani
    June 10, 2016 at 12:35 am
    Ok, this is weird. I managed to pull off a good shadow, but even though my element solid isn’t 3D, the car is still moving around. I have lights set up for the shadow to work btw.
  • Hanna Dean
    June 10, 2016 at 12:52 am
    depends on your shot , use mocha to track the car and then use the data on shadow.
    after effects built in tracker is useless if this is what your using
