Activity › Forums › Maxon Cinema 4D › object lifting another object
  • object lifting another object
    Posted by Richard Quinn on June 25, 2009 at 3:36 pm
    I am having trouble making one object lift another one upwards.
    I have added a rigid body dynamic to both objects, and put them in a solver object but the objects just pass through one another and do not collide.
    Cheers,
    Rich
    Brian Jones replied 17 years, 3 months ago 2 Members · 1 Reply
  • Brian Jones
    June 26, 2009 at 12:47 am
    try setting the solver Integration Method to Midpoint and crank the Oversampling, be sure the collision eps is no bigger than the initial distance between the objects – if there is no distance between the objects pull them a little bit apart.
