Activity Forums Maxon Cinema 4D Object inside glass jar is dark for some reason (Ocatne)
  • Object inside glass jar is dark for some reason (Ocatne)
    Posted by Velinsky Márton on August 14, 2019 at 9:19 pm
    Hi everyone! ????
    I’m trying to create this “jelly bean factory” scene from Cgshortcuts’s amazing course, but for some reason, the jelly beans are really dark in the glass jar while the other part of the scene is well light.
    What should do now?
    Here is the project file:https://bit.do/e4yCP
    Sam Treadway replied 7 years ago 2 Members · 1 Reply
  • Sam Treadway
    August 15, 2019 at 1:24 am
    I’m unable to download the file. The link seams dead.
    One thing to check if you are using standard or physical renderer is the “Ray Depth” setting under the Options tab in the render settings.
    If you have ambient occlusion turned on then this could be effecting the look also.
