Activity Forums Adobe After Effects Object follow a moving path
  • Object follow a moving path
    Posted by Marc Smith on July 1, 2021 at 5:40 pm
    Hi all,
    I’ve been working with AE for years and I’ve never had to make an object follow a moving path. Is this even possible? I have tried animating the path points then copying those over to the position on the object but it does nothing.
    Plenty of help videos on how to do it with a static path but not a moving path.
    Cheers,
    Marc
    Graham Quince replied 5 years, 2 months ago 2 Members · 1 Reply
  • Graham Quince
    July 3, 2021 at 8:03 pm
    Check out the Script called “Create nulls from paths” (it is a bottom of the window menu). When you open it, the Trace Path option will create a null which uses an expression to control the null’s position, which follows the path.
