Activity Forums Maxon Cinema 4D Object flips when animating on circle using “Align to Spline”
  • Object flips when animating on circle using “Align to Spline”
    Posted by Jeremy Grubaugh on February 17, 2006 at 10:15 pm
    I have a car that I am tring to animate in a big loop. Simple enough right? Well I placed a simple cirle spline and used the expression “Align to spline”…only problem is the car flips upside down when it hits a certain point. Ihave tangential on because I want it to have orientation.
    I feel as though there is an easy answer but my searches so far have yeilding no success. Thanks for taking the time.
    – JG
    Anna Walter replied 11 years, 1 month ago 4 Members · 4 Replies
  • Doug Bassett
    February 18, 2006 at 2:40 am
    Put your spline on the X,Z axis, apply align to spline to the obj. Then animate it. Now drop both in to a null obj and then rotate null back where you want it.
    Doug
  • Adam Trachtenberg
    February 22, 2006 at 4:40 am
    Make a copy of your circle spline, scale it up, check the “tangential” box in the align tag, then drag your scaled spline into the rail spline box.
  • Jeremy Grubaugh
    February 23, 2006 at 3:08 am
    That worked…Thanks a lot you guys.
  • Anna Walter
    August 16, 2015 at 10:33 pm
    Finally I could solve this. You are great! Thank you!
