Activity Forums Adobe After Effects object flipping on circular path
  • object flipping on circular path
    Posted by Ellen Osborne on May 20, 2014 at 7:06 pm
    I have an object following a circular path. It seems to be working fine except it flips its axis when it reaches the midway point between the top and the bottom of the screen. I have set it up by copying a circular path to the position on a null object. The problem happens when I use auto orient along path. If I don’t orient it along the path, then it doesn’t flip its axis, but when I use orient along path it flips at the midway point. How can I stop this?
    Thanks for the help.
    Mac Pro late 2013, CS6
    Ellen Osborne replied 12 years, 4 months ago 50,195 Members · 1 Reply
  • Ellen Osborne
    May 21, 2014 at 5:24 pm
    This works great. Thanks!
