Activity Forums Adobe After Effects Object changes proportions as I rotate it
  • Object changes proportions as I rotate it
    Posted by Eddie Scott on November 11, 2019 at 8:26 am
    I’ve encountered a really weird issue with After Effects, rotating an object will make it drastically change proportions (as shown in this gif) the comp size is 1000×1000 pixels and the circle is 868×868 pixels
    This stemmed from another issue where holding shift would lock the proportions to an equally weird size instead of locking it where it is. (I overcame this by just fitting it to the comp size and adjusting the scale property)
    Thank you in advance 🙂
    Eddie Scott replied 6 years, 9 months ago 2 Members · 2 Replies
  • Oleg Pirogov
    November 11, 2019 at 2:59 pm
    What is the comp’s Composition->Composition Settings->Pixel Aspect Ratio (is it anything different from Square Pixels?)?
  • Eddie Scott
    November 12, 2019 at 10:44 am
    Woah! thank you so much! It was set to “HDV 1080/DVCPRO HD 720 (1.33)”, I set it to square pixels and it fixed it instantly, thanks again.
