Activity › Forums › Maxon Cinema 4D › Object changes in picture viewer
  • Object changes in picture viewer
    Posted by Nicklas Pettersen on May 31, 2017 at 3:59 pm
    Hi.
    I am currently designing an avatar/character in Cinema 4D, and it looks all good when I render it using the Render View. When I try to render it in the Picture Viewer, however, the face of my character changes into a block instead. Do any of you have any suggestions to what the problem might be? Any help would be appreciated. I’ll attach two pictures – One before the use of Picture Viewer, and one using Picture Viewer.
    Picture 1:
    Picture 2:
    Best Regards,
    Nicklas Pettersen replied 9 years, 4 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    May 31, 2017 at 5:01 pm
    Looks like a hidden object that’s rendering for some reason. Hard to tell what’s causing it without seeing your scene.
  • Nicklas Pettersen
    May 31, 2017 at 5:22 pm
    I made the Face out of a cube, which I then put into a Subdivision Surface to create soft edges. When I render it in the picture viewer, it seems like it turns of the subdivision layer, only rendering the cube.
  • Nicklas Pettersen
    May 31, 2017 at 8:07 pm
    I found out what the problem was. In my Subdivision Surface object options, my Subdivision Editor was 5, while Subdivision Renderer was at 0, making it only show in the Render View. Thanks again for taking the time to answer me.
