Activity › Forums › Maxon Cinema 4D › Object Buffer not working
  • Object Buffer not working
    Posted by Daisy Millard on November 14, 2014 at 5:26 pm
    I am having trouble getting my object buffers to work. I have 3 object buffers that are to render into a quicktime movie file. My objective is to have two separate layers (one with the red people on it and the other being the blue river) so that I can insert another separately rendered alpha in between the two object buffers in AfterEffects. 1st object buffer is set to a null with has about 40 other nulls each containing a spline wrap, a spline that uses expresso to animate, and basic shapes that have been made editable.
    The 2nd object buffer doesn’t even show up when i render.
    I’ve attached the file so you can see it for yourself.
    8187_rivers03.c4d.zip
    Daisy Millard replied 11 years, 10 months ago 2 Members · 2 Replies
  • Emir Bojorquez
    November 14, 2014 at 6:28 pm
    Your second object buffer is not rendering because the object is Off in render (the Red Dot), you can’t make an object Buffer from an invisible object.
    GOod Luck
    Imagination is the best tool…
  • Daisy Millard
    November 14, 2014 at 11:58 pm
    Doh! Didn’t see that, thanks a lot for the help!
