Activity Forums Maxon Cinema 4D object buffer luma outline
  • object buffer luma outline
    Posted by Murat Pak on December 31, 2008 at 5:07 am
    I’m using multipass + object buffer to composite my data. I just started doing it.
    I use the object buffer as luma matte to my render. (select the luma from ae tree) But I have a little outline around my buffered object. How can this be solved ?
    I also saw many other problems have the same issue, too, but no solution.
    Randy Johnson replied 17 years, 8 months ago 3 Members · 3 Replies
  • Randy Johnson
    December 31, 2008 at 7:52 am
    In shake its called a diolate / erode node no clue in AE. You could also use a small blur. and in some situations using it as a key is not the best as you can multiply and divide the object buffer too.
    /randy
  • Jon Herron
    January 23, 2009 at 11:34 pm
    Im curious about this too. I always get this thin line when applying an Object Buffer as an Luma Matte.
    Any proper procedures to avoid or fix this?
    thanks
  • Randy Johnson
    January 27, 2009 at 7:40 am
    If you always get that issue try under render settings, select Multipass and ensure Shadow Correction is checked.
    /Randy
