Activity Forums Maxon Cinema 4D Object Buffer in C4D lite causes texture to disappear
  • Object Buffer in C4D lite causes texture to disappear
    Posted by Thomas Hannen on May 24, 2017 at 2:31 pm
    I’m trying to do a multipass render from c4d lite into after effects.
    I’ve set up a simple scene for troubleshooting purposes:
    I want to render an object (a red cube)
    and a plane in order to catch shadows, so that I can composite them into a 2D video clip in After Effects.
    I’ve set up the following multi-passes in Render Settings:
    (Enabled Multipass)
    Set up two object buffers with object ID 1 and 2
    And a shadow pass
    I’ve added a composite tag to each of my objects:
    When I render the view in c4d it looks right:
    But my multipasses are stripped of all texture:
    And the same is true in After Effects.
    I can export as RGBA, but then I will end up with the plane in my render, and I only want to use the plane as a shadow catcher.
    I can’t export as stills because I’m using C4D lite, and it’s maximum render resolution is 800×600 (I’m working at 1920×1080).
    What am I missing?
    Many thanks,
    Tom
    Adam Trachtenberg replied 9 years, 4 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    May 24, 2017 at 11:30 pm
    Object buffers are just alphas to be used in your compositing application to isolate your objects, so you need to render a beauty pass or whatever regular channels you need (diffuse, reflection, etc.) in addition to the buffer passes.
    In AE you use object buffers as luma mattes.
