Object buffer for reflections?
I’m working on a scene replacing some LCD screens in AE using object buffers and external comp tags. The screens are also reflecting in the floor object so when I replace its solid with footage, the reflection doesn’t…um…reflect the change. Has anyone come up with any tips or tricks to get around this? A friend at work suggested dupliating the LCD model on the floor to later comp in the reflected sources. Was curious if there was an alternate approach using buffers, comp tags and render passes. Thank you!
Craig Whitaker
MFA Candidate
New York University
http://www.craigwhitaker.net
