Activity Forums Adobe After Effects Object bending and following a 3d path
  • Object bending and following a 3d path
    Posted by Stig Olsen on August 22, 2019 at 12:02 pm
    Hi.
    I want to have a logo follow the path of a virtual 3d cube. By that I mean it should go upwards and then when it reaches the top of the cube, bend and move in z space. How do I set this up?
    Stig
    Walter Soyka replied 7 years ago 2 Members · 1 Reply
  • Walter Soyka
    August 23, 2019 at 12:10 am
    Here’s one approach: (1) lay out the animation on a comp which is mean to be the unfolded cube, then (2) make several square precomps, repositioning the unfolded cube in each to create the individual faces of the cube, then (3) build the cube from the precomps in step 2 with 3D layers.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
