Activity Forums Adobe After Effects OBJ. file in to Element 3d
  • Kalleheikki Kannisto
    September 5, 2016 at 7:37 am
    Two things you can do in Element:
    1) Enable auto-normals. Your model doesn’t seem to have come with surface normals.
    2) Use one of the Element’s texture mapping options (spherical, cubic, planar) instead of UV mapping, since the model doesn’t have such.
    For this to work properly without the need of the two above steps, the export from ZBrush (I’m not familiar with the program) should include normals and UV mapping (if such is used).
    Senior Graphic Designer
  • Ryan Thompson
    September 5, 2016 at 10:31 am
    Thanks so much! this worked for me, I had been having that issue with models for quite some time now
  • Coulter Mitchell
    September 9, 2016 at 10:26 pm
    That was it!
    Thank you Kalle!
