Activity › Forums › Compression Techniques › Obama YouTube Compression workflow
  • Craig Seeman
    May 9, 2009 at 5:20 pm
    I don’t know their workflow but it’s not too difficult to match that quality at all.
    Start with a good high end broadcast camera (you’re simply NOT going to get DV to look that that!) and shoot HiDef with a good lens. Use good lighting techniques. Color correct in post production as needed.
    Encode H.264 at 1280×720 at about 5000kbps 2 or multipass VBR and use your source frame rate. Upload.
  • Craig Seeman
    May 9, 2009 at 5:24 pm
    I’d thought I’d add their encode seems to have either interlacing or scaling artifacts. Watch his hand move. In addition the audio has too much room reverb. They could have used a lav or moved the boom closer with a mic that had better side rejection.
  • Barthelemy Glumineau
    May 11, 2009 at 8:08 pm
    and there is so luttle movement that it s easy to read, for us and for the “encoder”.
    https://www.kenstone.net/fcp_homepage/you_tube_hd_gary.html
    http://www.strangefamilia.com
