Activity Forums Apple Final Cut Pro Legacy NXCAM SD MPEG problem
  • NXCAM SD MPEG problem
    Posted by Gergo Szabo on February 23, 2011 at 10:34 am
    Hi There,
    I have problem. I have an SD MPEG2 file and FCP 7.0.3 when I import the MPEG file to the FCP it doesn’t see the audio tracks of the file (not even the QT). But when I import it to the MPEG Streamclit I can hear the audio tracks.
    Do you have any idea what can be the problem?
    Gergő
    Gergo Szabo replied 15 years, 6 months ago 4 Members · 7 Replies
  • 7 Replies
  • Steve Eisen
    February 23, 2011 at 12:59 pm
    Please read some of posts below and you will find out why.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Chris Tompkins
    February 23, 2011 at 2:31 pm
    You can’t edit Mpeg files in FCP.
    Convert it in Mpeg Stream clip.
    Export to DV50 or something.
    Chris Tompkins
    Video Atlanta LLC
  • Rafael Amador
    February 23, 2011 at 4:20 pm
    [Gergo Szabo] “I have problem. I have an SD MPEG2 file and FCP 7.0.3 when I import the MPEG file to the FCP it doesn’t see the audio tracks of the file (not even the QT). But when I import it to the MPEG Streamclit I can hear the audio tracks. “
    Hi Gergo,
    I don’t know the NXCAM, but I guess that its records the audio as MP2-Layer1.
    Is an embed audio format and FC (QT) can not read it.
    [Chris Tompkins] “You can’t edit Mpeg files in FCP.”
    Why?
    IMX is MPEG-2.
    HDV is MPEG-2.
    XDCAM is MPEG-2.
    No problem with MPEG-2 on FC.
    rafael
    http://www.nagavideo.com
  • Gergo Szabo
    February 24, 2011 at 10:40 am
    I have made an stream info in MPEG streamclip.
    The result:
    Type: MPEG program stream
    Duration: 0:01:00
    Data Size: 66.38 MB
    Bit Rate: 9.21 Mbps
    Video Tracks:
    224 MPEG-2, 720 × 576, 16:9, 25 fps, 9.10 Mbps, upper field first
    Audio Tracks:
    128 AC3 2/0, 48 kHz, 256 kbps
    Stream Files:
    M2U01046.MPG (66.38 MB)
  • Rafael Amador
    February 24, 2011 at 10:53 am
    [Gergo Szabo] “Audio Tracks:128 AC3 2/0, 48 kHz, 256 kbps”
    OK. The audio is AC3 (no MP2 as I thought) it could).
    You need a component to let QT playing that kind of audio.
    Try installing “Perian”.
    rafael
  • Gergo Szabo
    February 24, 2011 at 12:13 pm
    I have installed Perian and It doesn’t play the sound :S
    Anybody ever used a SD NXCAM MPEG2 files in FCP. The Apple support sais FCP 7.0.3 can play the SD MPEG2 files.
  • Gergo Szabo
    February 24, 2011 at 12:26 pm
    Here is the solution:
    You have to copy all the folder tree of the memory card, and you can ingest the files with “Log and Transfer”. It converts all the files to ProRes422.
