Activity Forums Adobe Premiere Pro NXCAM AVCHD spanned media and workflows
  • NXCAM AVCHD spanned media and workflows
    Posted by Alex Udell on May 24, 2013 at 4:12 pm
    Hey All…
    sorry….they are now asking me to checking into the HXR-NX30.
    This one shoots to AVCHD files and suppports clip spanning.
    Some searches yield some ppl running into problems with spanned media….but nothing recent…
    All the stuff we shoot is pretty short duration, so I’d expect not to run into spanning issues to often.
    How is PPro with spanned source from this camera?
    How is Prelude? Can it be mereged in transcode if necessary?
    Is it folder stucture for file single file based?
    Thanks…
    Alex
    Paul Neumann replied 13 years, 3 months ago 4 Members · 5 Replies
  • Jeff Pulera
    May 24, 2013 at 4:20 pm
    Hi Alex,
    I recently shot a 2.5 hour stage event using a rented Sony AX-2000, which ought to be recording the same format you are discussing. I copied the ENTIRE contents of the SDHC cards onto video hard drive. Did NOT run through any Sony utility.
    I then used Media Browser in Premiere CS6 to Import. Browser did not show a lot of clips – I think it has an intelligence to know that the bunch of smaller clips all belong to the same larger clip – so the import showed as one clip name.
    No glitches or audio sync issues at all. Matched to HDV second camera angle footage and sync was perfect for the entire show.
    I think a lot of folks that have problems with AVCHD are messing with the files first, joining them in the Sony utility before trying to edit.
    Jeff Pulera
    Safe Harbor Computers
  • Alex Udell
    May 24, 2013 at 4:26 pm
    Hey Jeff….
    That’s great info….thanks….
    What do you think about Prelude?
    While it’s not necessary to transcode to work in PPro…
    If we shoot material then want to drop it in our library….
    I’d want to be able to end up with a single clip for searching/naming purposes at the OS level.
    Sorry to be a PITA….
    thanks…
  • Jeff Pulera
    May 24, 2013 at 4:40 pm
    Would you believe I’ve never opened Prelude, ever? I guess I don’t need it for my workflow, which is typically HDV with some AVCHD from time to time.
    Jeff Pulera
  • Gus Evangelista
    May 26, 2013 at 2:30 am
    Prelude (through Media Encoder) will convert your spanned AVCHD clip into one clip, i.e. a single Prores, MXF, etc.
    OR you can use Premiere’s Media browser, import the recognized ‘spanned’ clip into the timeline and export as one clip (again through Media Encoder).
  • Paul Neumann
    May 26, 2013 at 4:02 am
    Check out the review of this camera on Pro Video Coalition and a bunch of the articles on the Beyond AVCHD crystal ball.
