Activity Forums Sony Cameras NX5U is sensitive to RF energy
  • NX5U is sensitive to RF energy
    Posted by John Lenihan on August 30, 2010 at 3:51 pm
    I discovered that the NX5U is sensitive to RF Energy and I want to save you the frightening moment I had recently…Twice.
    1. I had a wireless video transmitter on my camera to remote monitor what my other camera operator was shooting in a multicam shoot.
    It was a cheap one at about 400 mhz. The device was laid on top of the camera. Suddenly, the focus system started moving from zero to infinity and back. I found that the transmitter was laid across the keypad area under where the monitor closes. When I moved the antenna about a foot away, the ghost focusing stopped.
    2. Another day, no wireless transmitter. However, I had a second wireless receiver mounted on the rear hot shoe. The first wireless receiver was mounted on the front hotshoe and I use this configuration all the time. The rear wireless receiver, in the 650 mhz range, had its antenna laying across that same keypad which resides on top of the camera. Suddnely, the zoom started moving to full zoom. I could zoom it back but as soon as I let go of the controls it went to full zoom.
    I roted the wireless receiver 90 degress so the antenna pointed out to the right of the acamera and the ghost zoom stopped.
    Sony Please fix this.
    Users, please be carefull.
    John Lenihan
    LeniCam Video Productions
    https://www.lenicam.com
    Matt Westerman replied 14 years, 9 months ago 5 Members · 6 Replies
  • Jeff Breuer
    August 30, 2010 at 11:33 pm
    Thanks for the heads up John!
  • Scott Gifford
    September 16, 2010 at 7:27 pm
    Hi John, congratulations on accepting the host position on the forum. I believe you are the right guy on this site.
    I was talking to one of my shooters about a similar problem you described regarding ghost focusing. He operates a Sony Z5. When his camera is close to his apple iphone, the zoom controls and focus start moving. He believes there is some FQ waves which can interfere with the controls of his camera.
    Scott Gifford
    Scott Gifford Studios
  • John Lenihan
    September 16, 2010 at 10:14 pm
    Thanks for the update Scott,
    Hi havent’ done conclusive tests, but it seems like it is the keyboard area that is underneath the lcd panel that is most sensitive.
    That looks like the same design as in the z5, so I am not surprised.
    I wish that our friendly Sony Product manager would be an active participant so we can help him help make the product better.
    John
    John Lenihan
  • Ruy Fajardo
    October 27, 2010 at 8:54 pm
    Hi dude thanks for the input, i just want to know if maybe that could be happening because bad shielding in the RF receiver, you said that it was a cheap one. could you confirm that the ghost happens altough GPS is turned off?
    best
    Rodrigo
  • John Lenihan
    October 27, 2010 at 9:35 pm
    Rodrigo,
    I confirm it was NOT while the GPS is on. I haven’t found a use for the GPS at this point, and it just drains the battery too much but it is cute.
    The problem I talked about was not a problem with my receiver. I use a sennheiser G3 and there is not problem at all.
    The problem was with a video transmitter I use connected to the composite output. I use it to monitor my assistant’s shot’s so I can make sure are not moving at the same time. The problem occurs when the transmitter antenna is laid across that top menu structure. That is when the zoom and focus motors go nuts.
    If I make sure the transmitter antenna is pointing down behind the camera, there is not a problem or if the antenna from the transmiter is mounted on the tripod.
    John
    John Lenihan
  • Matt Westerman
    November 20, 2011 at 2:17 pm
    This is great info I’m having the same ghost focusing problem with my NX but it has to do with the communicaon system we are using (cheap) and the length of time that the camera is on. Once I restart the camera the cycle seems to start all over again but the length of time it takes for the problem to come back seems to vary greatly. Still running tests to see if I can nail down what is triggering it but I would love a fix from Sony.
    Matt Westerman
